FWIW, it's been done before, and researched.
https://link.springer.com/article/10...664-011-1580-6
We proposed and fabricated a thermoelectric generator (TEG) using the engine water coolant of passenger vehicles. The experimental results revealed that the maximum output power from the proposed thermoelectric generator was ~75 W, the calculated thermoelectric module efficiency of the TEG was ~2.1%, and the overall efficiency of electric power generation from the waste heat of the engine coolant was ~0.3% in the driving mode at 80 km/h. The conventional radiator can thus be replaced by the proposed TEG without additional devices or redesign of the engine water cooling system of the existing radiator.
I bet they meant 'alternator'. But 75 Watt ain't enough.
But one could simply buy a liquid to liquid type generator: https://thermonamic.en.alibaba.com/p...EG600_48V.html
600 Watt, that's more like it. 48 Volt, ah well that needs a buck converter.
Pity it weighs 75 kilograms. No free lunch :/
