Old 10-04-2018, 12:29 PM   #17 (permalink)
ThermionicScott
ScanGauge <3
ThermionicScott's Avatar
Use solar panel and teg to do an alt delete.
Use teg so the battery doesn't drain as fast while driving.
Then solar panels can replenish the battery during the day.
The teg would also continue to make some power after the car is turned off.
But if you have an electric vehicle you don't have to worry about any of that.
Put a switch on it, and you could have a control-alt-delete!
Best tank (so far): 32 MPG
