If you actually keep to 80 kph the air dam effects would be less than if you were doing say 120 or so.
But with gas over $4 a gallon it's probably worth it.
How's the snow there?
Ever consider a block heater to reduce or eliminate warm ups?
I usually drive at 90 kph so not to upset everybody behind me.
I do have a block heater that I plan to use this winter.
No snow here yet just outside of Toronto. Likely another month than anything goes.
That being said I will be putting my snow tires on at the end of October...there's another strike against me.
