3D measurement, imaging and realization technology
How Japanese Race Car Manufacturer Accelerates Product Design Process
How Japanese Race Car Manufacturer Accelerates Product Design Process – FARO 3D Blog
I think anyone using cardboard templates to fabricate and fit aerodynamic pieces on to their project car like an inept tailor will like getting a peak at how the pros do it.
Looks to be a 2017 blog entry.
Reverse Engineering: Complex Designs & Black Parts
Previously, Mooncraft carried out its measurements using only 2D instruments such as calipers and layout machines. However, as 3D computer-aided design (CAD) technologies advanced and grew in popularity, car component designs became more complicated as well, and it was no longer sufficient to rely on subjective judgment. This led to Mooncraft introducing the FARO ScanArmŽ – a portable coordinate measuring machine (CMM) integrated with a Laser Line Probe – to its operations in 2005.
There is one of those community workshops near me called Maker's Works, I wonder if they have any 3D scanners they are able to loan/rent out to hobbyists.
EDIT:
They have lots of software.
https://www.maker-works.com/software-tools/
Okay, found their 3D scanners........................
Scanning Objects
https://www.maker-works.com/cadcam-toolchain/
Cubify Sense
This hand-held scanner can capture 3D objects as small as 8” x 8” x 8” up to nearly 10’ x 10’ x 10’, with accuracy of about 1mm. Software produces a 3D model in STL format.
I've seen videos of these in use.
https://www.3dsystems.com/shop/sense...ectFrom=cubify
The Sense 3D scanner is light, highly portable and small enough to fit in your laptop bag so you can scan data wherever you are and bring it back to the office to complete and enhance your designs.
