Old 10-08-2018, 03:23 AM   #3 (permalink)
freebeard
What's your plan? Just a heads-up?
The Mooncraft article is only about capture. seifrob points out an alternative, but looking for a link I see that 123D Catch is gone no longer supported.
It only obtains a dense polygon mesh. The Makerworks CAD/CAM toolchain graph (dating to 2015) shows their scanner outputting to an STL file. That's a tool-path.
Depending on what you want to do, a box modeler or parametric modeler might be appropriate.
If you want CFD, and you know you do, then look into Open VDB. It's supported in Blender, which will do animations.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
