Originally Posted by teoman
It does not need to be accurate as long as it is consistent.
Fixed that
However, even if it precisely measures how much fuel it injects, it cannot measure how much vapor gets sucked into the air intake from the vapor trap. On a hot day after a fill-up you may get magically good MPG as the intake air is enriched by fresh gas vapor.
