2002 Civic HX 5-speed.
2-door, sliver exterior black interior
Clean / clear title never wrecked, all original body panels with honda tag
325k. Miles (yes that's correct)
Civic "HX" gets 36mpg city & 44mpg highway. Much higher if hypermilling
PRICE: $1200
aftermarket 15" wheels, Yokohama tire's. CD Player with Bluetooth, usb, aux. aftermarket front door speakers. Stock rear speakers. 25% tint all around. No rips, no tears, no holes on the seats or anywhere inside.
EVERYTHING WORKS! again 110% functional car. Cruise control works, A/C works & is cold, all interior, exterior lights work. Power steering etc.
timing belt, water pump, timing belt tensioner & timing belt cover, spark plugs, valve cover gasket, battery, alternator, a/c belt, alternator belt, brake pads & rotors, clutch pressure plate, throw-out bearing & pilot bearing, radiator, upper & lower radiator hoses, thermostat, a/c condenser .......all have been replaced within the last year of ownership.
ISSUES: drivers door handle is cracked. Still work normal just plastic handle is cracked so you've gotta be easy when u grab it.
Check engine light has been on for at least 3-4 years. It is emissions related; I've never changed any of the O2 sensors so it could be that. Dunno, has no affect on running, drive ability at all.
One tire is low on tread, the other 3 are fine. No sure why bc. all 4 are matching Yokohama's
The black cloth on the door panels by the window crank started to come unglued so I stapled the cloth back to the door panel. Works great.
100% NO RUST:
$1200 bucks.
FULL DISCLOSURE:
I am in somewhat of a Pinch, I MUST sell this Civic HX no later the October 15th. or I wont be able to pay my other car payment. I love this car an have owned it for more then 5 years. I drove it to Jacksonville FL. two weeks ago (1400 miles) an it ran flawlessly. Cruise control set at 80mph the entire trip.
I must sell within 6-days. Location is 80 Rosewood Court, Chillicothe Ohio 45601.
Cell # 740-804-7720
