Old 10-15-2018, 08:51 AM   #12 (permalink)
Joggernot
Joggernot's Avatar
Things my car does (2018 Honda CRV with CVT). All of these assume the car is not moving. If the car is moving, nothing happens.
1. Car off: Gear in Park: Foot on Brake: -- Push button and the engine starts.
2. Car off: Gear in Park: Foot off Brake: -- Push button puts it in Accessory Mode. Test your car to see what still works in Accessory mode.
3. Car off: any other configuration: -- Nothing happens, but you might get chimes.
4. Car on: Gear in Park: -- Push button and the engine stops.
5. Car on: Gear not in Park: Foot on Brake: -- Push button and the engine stops with chime warning to put it in Park.
What I do is come to a fresh stop light, use #5 to stop the engine. Put it in Park. Wait for the light to change. Put foot on Brake; push the button to start the engine; shift to Drive and go. With a couple cars in front, you have time to do this without holding up the line. If I want Accessory Mode, use #2. Nothing but the radio seems to work in my car in Accessory Mode, so I just sit there in the silence.
