Originally Posted by redpoint5
I get the impression that turbo charging a smaller engine is no longer the fuel efficient way. Perhaps due to the lower compression ratio?
So these turbo engine vehicles might get better fuel economy in stop and go driving, but worse in steady cruise?
I know Toyota gave the Gen III and IV Prius a larger displacement than the Gen I and II. Displacement must not be such a huge economy penalty as long as you can keep the engine near the BSFC sweet spot.
I don't believe everything this guy says. But he seems to have a good point. Traditionally turbocharged engines are made with lower CR's, use a lot more high load enrichment and retard the timing much more than N/A engines. The result is worse fuel economy. But if other forms of knock control are done properly, like cooled EGR, a turbocharged engine can theoretically get good fuel mileage.
[YouTube]
