Old 10-17-2018, 10:24 AM   #21 (permalink)
kach22i
Originally Posted by hat_man View Post
kach22i.....
I like the chin spoiler. Did you use the round edge as the attachment point or the flat edge? I saw the cove base addition and wondered... if you used the flat edge as the attachment point would the rounded edge work like the cove base did?
The vinyl cove base was installed in the same orientation as it would be on a wall, cove at the bottom. See images in posts #29 and #35 in the link below.
http://forums.pelicanparts.com/off-t...fective-2.html
I used something like 100 screws to secure it to the old lawn edging for Phase II, that curve tube in the lawn edging was precarious.
The proper way to do this is to start out with conveyor belt material, and if you want a lip spiltter at the bottom find something at the hardware store "L-Shaped" that you can use as a bottom lip - rivet or screw.
See attached image - an untested idea, will need to bend in 3D.
Depending on depth of conveyor belt material you may have to back brace it the way I did with scrap metal.
aerohead (10-17-2018)
