I imagine MAP or MAF measure air flow good enough. The cobalts have both I don't know if the MAP works as a back up? They don't have to be precise, just consistent, the LTFT will adjust.
Yep, car doesn't care what the fuel is until it exceeds the fuel trim limits.
Wife filled the 15 Rogue with E85 shortly after getting it out of habit with the Impala. Next day I noticed it didn't start as instantly as normal, after a few mile the light came on and figured out what she did. Ran fine the whole time.
The link in #9 shows how much timing is retarded with E0 vs E30. I can't tell with the SG2 if my timing changes any with blends. If I gained the same 4 hp as the Malibu with almost the same engine as the cobalts I don't think I could feel it.
