Old 10-20-2018, 01:36 PM   #1 (permalink)
Nedlom
Advice on fitting a coolant heater please
I'm trying to figure out how to fit a coolant heater, and just want to check my thoughts with you guys.
I want to fit it to the hoses coming to/from my cabin heater right?
Do I fit it "inline" e.g. cut the hose and connect the two ends to the coolant heater, or in parallel using t-peices?
None of the ones I've seen have the same fitting diameter as my coolant hoses (always smaller) if fitting "inline" do I need to worry about this as a restriction, or is it not an issue as long as it's only for the cabin heater hoses?
Thanks,
Nedlom
