Old 10-22-2018, 08:52 AM   #3 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 43.77 mpg (US)
Corroded battery cables act exactly like a dead, dying, or discharged battery. Remove both cables, clean the connections at both ends, and check for corrosion between the cable and connector at both ends of both cables. If you see any sign of corrosion in the cable, replace both cables.
Get a battery charger. A six amp charger is plenty big enough. Fully charge the battery, then try to start the car.
22 Maverick: Summer 2022 burned 62.74 gallons in 3145.1 miles for 50.1 MPG.
