Old 10-22-2018, 07:47 PM   #654 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by mannydantyla View Post
Bill, clearly it would be too late now but did you ever consider making it a rear-engine, rear-wheel-drive? The Prius engine and drivetrain could power the REAR wheels! Front wheels on the VW remain the same - steering, braking, etc. The Prius's steering stuff would need to be welded solid so that it can't turn. The throttle cable is a wire so that's no problem, but the shift lever is a cable (right?) so that might be trickier.
I guess the engine would need to fit in the trunk, would still be a huge challenge. Same concept could be applied to a pickup truck, and you could put the engine in the bed of the truck.
It probably wouldn't work or fit but it's a neat thought.
Ever heard of the Pontiac Fiero? GM took the drive train and front suspension of a Sunbird and put it under the rear of the Fiero. It worked for them.
Actually I briefly considered using a SECOND Prius drive in the rear, but that would not have left much room for anything else.
The Following User Says Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020)
