Old 10-22-2018, 09:51 PM   #11 (permalink)
laser3kw
I just bought a second ScanGauge, You can "daisy chain" them together and then monitor 8 functions. just use a standard Ethernet cable and plug it into the open port on each unit.
I monitor
inlet air temp
coolant temp
instantaneous mpg
tps
long term fuel trim
short term fuel trim
lod
battery voltage
The Following User Says Thank You to laser3kw For This Useful Post:
TDFbound (11-25-2018)
