Old 10-23-2018, 06:09 AM   #30 (permalink)
kach22i
Originally Posted by hat_man View Post
I really like the aesthetics of the Toyota wing arrangement.
Looks like it has similarities to the first generation Honda Ridgeline's profile, a shape claimed to be influenced by wind tunnel testing.
2005 Honda Ridgeline best image gallery #10/17 - share and download
As far as the study/development sketches posted (not final designs), they represent a single idea or concept. The reason none of them flute or flare out like the Toyota and Honda is my S-10's Sportside bed.
A standard fleetside bed would have more opportunity for elongation at the base.
This elongation might help prevent air on the sides from tumbling into the bed area.
Let me say that these concept sketches are untested and may induce some uplift.
The main idea running though them is going from the rectangular cabin to a half circle with fewer vortexes and more equal surface pressure.
https://appliances.knoji.com/how-to-...t-booster-fan/
https://forums.sketchup.com/t/drawin...to-round/18660
https://weldingweb.com/showthread.ph...quare-to-round
There is a small hovercraft in the UK that goes from round to square thrust duct so that reversing rudder deflectors can be used, the transition also expands the thrust area a bit. The sketches I did are sort of the opposite and reduce the drag area - in theory and if attachment of air is maintained.
Don't go too steep with the angles and you will be okay.
The question asked seemed to be; will this aft cabin hood funnel more or less air into the leading edge opening of a half bed cover.
More I would guess.
However once a static bubble of air pressure is established the rest of the air flow would just go around it I suspect.
I for one would fear some kind of buffeting with any half bed cover.
These could be unfounded fears, but personal experience with cross winds, passing large trucks and being passed tells me air does not always flow in polite uninterrupted smoothness they way I wish it to.
EDIT:
Found an older thread with great information and images in it.
How to improve fuel economy with a tonneau cover
https://ecomodder.com/forum/showthre...ver-124-5.html
7-pages long, got sidetracked with trailer towing and aircraft but it's all good.
