10-23-2018, 03:06 PM
- Doesn't solid state imply a non-chemical store of energy?
- What voltage does the cell produce?
- What method is used to charge the cell and is it tolerant of over-charging?
- Does it require a BMS?
- How flat is the discharge curve?
- If dendrites do not form, then can the cell be discharged completely without causing undo damage?
- What are the current development challenges?
- How difficult/expensive is creating a sub-micron layer of lithium?
- If sodium is used, is there risk of fire if a damaged cell is exposed to water?
