I will make a offer you can't refuse...
Well, with 23.000 cycles, it can last a lot. Just that makes it a best optium than lead acid, since lead acid it's around 300 cycles, so the solid state have 76 times longer life.
Even if a lead acid was still 50% the price of this new solid state battery for the same Kw/hour, by calculations the Braga solid state battery would last much longer, making it 37 times better if you think for decades. But even thinking as just 6 year investment, if would be cheaper for such years, since lead acid don't last even 3 years in general.
You can discharge it complete or nearly, If I remamber well, and charge very fast, in minutes. Works well on very hard winter too.
With deeper discharge you don't need too much extra KW/hour battery, making the Braga battery another advantage, since it could be a small model with even less KW/h than a giant lead acid that's reccomended to discharge only 50% or 60%.
I reccomend you to accept the offer, since the second round would be... well... be too hard:
Let's pretend like weight and space are not a factor.
Only price, depth of discharge, life span, reliably matter.
I already have one forklift battery for off grid experimentation, it's just a baby at 560lb and I don't have much problem moving it around. I should be able to handle a couple of 2 ton 24v batteries.
