I would also locate it in the rear under the intake just because of heat issues. GM makes one that
might fit. I have a really, really, really, old one on the shelf and I will get measurements, pics, and possibly a part # for you tomorrow. This will heat the coolant in the block around the cylinders as it was designed to do.
I would do it now, because there is no later
