Larger rims with the same outer diameter means shorter sidewall height.
Which means that when the sidewall flexes on contact with the road, it bends much sharper than a high sidewall would. Hence more friction.
Then, running them at higher than OEM pressure will have much more effect on FE, diminishing the difference with high sidewalled tires.
