Old 10-27-2018, 10:15 PM   #3504 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I have such little time each week on the computer,it would be a big favor if you would either re-post the data,or give a link.Otherwise,I just slip further behind.
Is it a self-imposed limitation on internet, or do you not have internet available at your abode. I can get you a laptop if you just don't have a computer.
You might consider those who died from rapidly-intensifying storms which 'came out of nowhere' recently.
With less anthropogenic carbon dioxide in the atmosphere,additional heat which made it into the Gulf of Mexico,might have dissipated into space,leaving cooler Gulf waters.Since it didn't,there was more available heat energy for hurricanes like Michael and Yutu.
Some say that we have benefited from global warming overall. Certainly we have benefited since the globe has been warming 14,000 years ago. Many more die of cold than from excessive heat.
The trick is determining what the ideal temperature is, all things considered, and then determining if keeping it near that temperature is feasible or beneficial given what we would have to sacrifice to achieve that temperature.
I don't dismiss the possibility/probability that some storms are more violent due to warming, but is it worse than the alternative of being too cold?
I tend to believe we have benefited from the warming, even to this day, especially given some predict continued net benefit until 2080, at which point we will have net negative consequences.
aerohead (10-30-2018)
