Originally Posted by royanddoreen
Same circumference is not the case with the Niro as I stated earlier the circumference of the 18” option on the Niro is 1.1” larger than the 16” standard wheel which is unusual but i’m Thinking this is killing the mpg.
Not to be pedantic, but:
The 18” tires have a 1.1% larger o.d. also.
1.1% is way less than 1.1", if your wheels are less than 8'4" tall.
In either case the sidewall on the 18" rimmed tires will be much narrower, so if it has to flex the same distance it will bend much sharper, and that's all extra friction.
