Old 11-01-2018, 12:39 PM   #60 (permalink)
NeilBlanchard
I commuted to work in the PEBL for a second time, today.
I tightened the motor chain after I arrived - I hope it stops stretching at some point. Or, maybe something is slipping? I will find out.
It took about an hour an 10 minutes - at least 4 minutes from being stuck in traffic (!) - I was waiting to get to the access point of the second rail trail. Next time, I will go to the access point on the next road north, which is farther from Rt 119.
I am going to work on moving the Cg - by mounting the batteries under the floor as far forward as possible; right behind the pedal well. Because, I tipped it over last night as I was backing out of my driveway. The driveway slopes down to the street, and the street is a fairly steep hill. I turned so the rear wheel went up the hill, and it fell over onto the right side.
