Originally Posted by JSH
The difference between the forces in the Model 3 and Model S mostly due to the difference between the vehicle weights. The more a car weighs the more force it must dissipate when that car smashes into an immovable object. A Model S weighs up to 1000 lbs more than a Model 3. Weight is a disadvantage when hitting a immovable object. The test is only tangentially relevant in the real world.
This is why the NHTSA very clearly says that crash ratings are not comparable between different classes of cars or cars in the same class that differ by more than 250lbs.
EDIT: Per the Jalopnik article linked above; the cut-off for a 5 star rating is a 10% chance of injury. A car with a 29% chance of injury would get a 2 star rating.
The Model 3 scored lower than the BMW 3 Series, Mercedes C-Class, and Audi A4 in IIHS crash tests. That blows a hole in the "Tesla Model 3 is the safest car ever" headlines.
The IIHS hasn't tested the 3 yet AFAIK.
https://www.iihs.org/iihs/ratings/ve...oor-sedan/2018
The 3 has the "lowest probability of injury" of any car tested by NHTSA.
So basically, when Tesla says its Model 3 has the “lowest probability of injury” ever tested by NHTSA, it means that the overall VSS score (which represents the “relative risk of injury with respect to a baseline of 15 percent”) of 0.38 is lower than that of any car ever tested.
