Old 01-17-2008, 02:01 AM   #17 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
DifferentPointofView -
Originally Posted by DifferentPointofView View Post
Basically, there are flaps that lay down on the front bumper on hinges, and is bent at the tip at an angle. At slow speeds, they stay down, but when you go fast enough air is forced under the flaps because the bend at the tip is at an upward angle. The air being forced under it lifts the flap into the air, and is pressed up against the grille opening until you have to stop, where they fall back down onto the front bumper.
Maybe not the best idea, but it's a start.
I like it. I was thinking the same thing but I was being more complex because I was thinking of a flap that was hinged at the top and "pushed" by the air in a similar way. But, a flap that just falls back down is nicer because gravity helps out (mine would have needed a spring). That sounds really easy to do. Hinge some plastic and put little bumpers to raise the flap :
CarloSW2
American Solar Energy Society
