Originally Posted by ThomCat316
Which way should I go? Opinions are very welcome!
I say if you have always wanted to do a belly pan, then now is the time.
If not, go the least amount of work path.
I forget where I saw it, but someone in the forum had some niffy ideas on easily removed panels, I think they slid into rails and were only secured front and back.
Maybe it was a double "L" stacked or a channel of some kind running along each side. In either case it saved putting a lot of holes in the car, and servicing was a breeze.
