From a consumer point of view, having suspension arms on both sides of the wheel makes changing tires much harder.
It also adds cost and complexity to the assembly. Sure, wheel bearings and CV joints and etcetera wear out over time, but it costs the consumer much less up front to have the wheel attached outboard in the simplest manner possible.
Also, wasn't heat an issue with inboard brakes?
