Old 11-11-2018, 03:16 AM   #68 (permalink)
redpoint5
90 day: 29.78 mpg (US)
And the LEDs? The diagrams I've found use several transistors, looks like it's the design used by most of the "protection boards" sold on eBay.
Is it simply a small LED with an activation voltage of ~2.5v on each capacitor, designed to very gradually run them all down to an equivalent level?
EDIT: 6 caps ordered.
It's been a while since I tried balancing caps. Basically you want the LED and diode to equal about the maximum voltage of the cap. So you want a voltage drop of about 2.5v. When a cap goes above about 2.5V, you want the LED burning that voltage so it levels out.
I don't really think any of that is necessary in a super cap bank for automotive purposes, but putting in the balance diode and LED is cheap insurance. The higher charged caps will bleed off charge faster anyhow, creating a natural balance.
Ecky (11-11-2018)
