Old 11-13-2018, 12:38 PM   #22 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Indeed, you are really missing the idea though.
It is a quick test, filter will not collapse unless you use significant rpm * throttle. And you will know if humidity has an effect on « perceived » octane rating of fuel.
Forget the air filter, install soaked and non restrictive rag in filter box.
The objective is to determine if water (humidity) has an effect on fuel economy. If it does, then more elaborate non-temporary solutions can be devised.
