Old 11-15-2018, 12:43 PM   #80 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Looks like my 12v lead acid battery has had a very timely demise - this morning it was 15 degrees, and my car wouldn't start using the starter. Rolled it down a hill and dropped the clutch to get to work, but I need this up and going soon.
These look promising to run in parallel with the caps:
https://www.batteryspace.com/li-ion-...lead-acid.aspx
There's a 20ah pack for $130, and one with an LED balancing circuit for $190. Thoughts?
I've got 2 of those batteries, and wired in balance leads, but don't have active balancing. I can throw the battery on my balance charger if I ever need to, and I have a cheap voltage reader that I can connect to get a quick read on the individual cell voltages.
One battery has been in my Prius for 2 years, and the other I keep around for experiments or in my jetski during the summer.
It could probably crank a 4-cylinder engine by itself, and I start my 2-stroke jetski with it.
The problem is that the battery is not supposed to be charged when below freezing. I think it can be charged at extremely slow rates below freezing, but how would one regulate that?
It drops below freezing in the Portland area, but my Prius lives in a garage, and the battery compartment is in the cabin. I don't think the battery ever actually sees freezing temperatures, so I feel confident it will last a long time. That said, I'm not so sure it would hold up to underhood temperatures; especially when well below freezing.
There's usually a code for 10% off if you search online, which basically covers shipping.
