Old 11-16-2018, 02:59 PM   #7 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I personally wouldn't idle to warm up.
Get a temperature gauge so you know what coolant temperatures are doing, and set an alarm for some upper limit, like 215 F. Then grill block in a way that you can quickly add/remove it. I use foam pipe insulation wedged in the grill slats.
Can you put a higher wattage block heater in? An oil heater would help too.
You could add insulation to the engine, like a blanket or something, to retain more heat.
The Following 3 Users Say Thank You to redpoint5 For This Useful Post:
101Volts (11-25-2018), Isaac Zackary (11-16-2018), skyking (11-23-2018)
