The motor turns the wheels! We got the motor powered up and turning the front wheels while the car in on the lift. The motor and transmission will have to be adjusted a bit to get rid of a small wobble but otherwise it looks like it will work.
Has any one had any experience stiffening a cars suspension? I am going to be about 600 lbs over weight in the back of the car. The springs as they are now are almost bottomed out.
Here is a picture of the car fully loaded. You can see how bad the sag in the back end is.
