Old 11-18-2018, 02:00 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder , Rasmus
Originally Posted by IlRasmusIl View Post
i have owned the car for almost 9 months now and put 100.000 km on it.
Seriously ? 11000 km per month
I bought the original Renault Zoe 16 inch "Aerotronic" Rims which returns the same consumption as the smaller 15 inch aluminium rims.
With the low rolling resistance Zoë tyres on them ?
The wheel shape and tyres seem to compensate for the (usually) higher weight (and higher fuel consumption) of the bigger rims.
I plan on getting it lowered 40 mm.
Should be good for fuel efficiency.
and cutting of the rear muffler.
Why ?
Reducing back-pressure may make the engine run worse, not better.
As I drive a lot on the Autobahn in Germany at high speeds
Driving slower would help to improve your FE ...
If you want to drive fast, you need to look into aerodynamic modifications.
