Old 11-19-2018, 01:11 PM   #6 (permalink)
redpoint5
90 day: 43.3 mpg (US)
If your fans are kicking on, then don't grill block.
I've run a partial grill block in the summer, but I monitor temperature and have an alarm set near where the fan activation temperature is.
If you use AC, then I wouldn't bother grill blocking. Better to get good AC efficiency.
Slow acceleration doesn't really save much fuel. Engines are efficient at higher loads. Avoiding brake use is much more important.
slowmover (11-20-2018)
