Old 11-19-2018, 11:16 PM   #2 (permalink)
me and my metro
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Be careful that the smaller diameter wheels will fit over the brakes. Studless traction tires are very soft, whereas studded tires are more like mud tires. Studless traction tires work pretty well but burn up in the summer heat here. Do you need studs to go over the pass to Bend? It is usually traction tires or devices on 10k gvw not towing on the passes. If it is chains required you probably shouldn’t be up there.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
redpoint5 (11-19-2018)
