Old 11-20-2018, 05:02 PM   #6 (permalink)
19bonestock88
Insight (Winter) - '21 Honda Insight EX
90 day: 47.43 mpg (US)
Originally Posted by TDFbound View Post
Fingers crossed the car is not impossible to get working correctly. Just heard back from one of the well-known local import mechanics and he quoted “several thousand dollars” to rebuild the engine with new rings to stop using oil. I’m guessing rust repair and a paint job won’t be cheap, but “several thousand dollars” to work on an old and fairly simple engine just seemed a bit shocking. How much does it usually cost for something like that?
I agree with the above, a quart per oil change (3K mi)isn’t too bad...
That being said if you wanted to rebuild it *shouldnt* cost several thousand, unless you’re building it to make some serious power... if you could get by without having it bored over (and thus having to replace pistons) it would likely only be a few hundred in parts to make *everything else* new or good as new...
Either the shop charges a lot per hour for labor or they’re gouging you just because it’s an import... I hear lots of “ them little import cars” talk in rural communities, just because it’s not a Ford, Chevy, or Dodge/Chrysler... they shut up when I tell them my was assembled in Tennessee...
My last Ecotec project...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
TDFbound (11-20-2018)
