Old 11-20-2018, 09:05 PM   #21 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Well I got a couple pieces of cardboard and stuck them in front of the radiator. I only put a couple clips back in to hold the plastic piece that goes above the radiator. That way I can get in there and slide one cardboard piece over and reveal up to 50% of the radiator. I also left some cuts to let air into the top part that apparently cools the electric drive since even after a short drive that radiator felt warm, so I figured it probably needs to be partially uncovered, whereas the radiator for the engine can be covered up to nearly 100%.
I also like the idea of bicycling instead. I need to get my ol' 27" ten speed fixed up. It has a broken spoke on the rear on the sprocket side and because of that the rim isn't straight. So I have to adjusting the rim brakes to where they either rub or to where they don't brake. Right now I kind of have them in the middle, but the rubbing is still noticeable, enough to make pedaling harder than normal, and they don't brake like they should. The front derailleur is also a little out of whack. But that shouldn't be hard to fix.
And I need to get a headlight, especially if I'm going to be driving around at night. I did put a Schmidt's Original Nabendynamo on my wife's bike. Kind of expensive, but very nice and robust. I think I'd like to do the same to my bike. It may be overkill, but I guess I like overkill. I also got her a lamp that has a capacitor that keeps the light lit for as much as a minute after pedaling. It would be nice to have the same on mine. Anything that doesn't include batteries that can freeze would be a good idea. I've tried battery lights and they always end up dying after a few months or even weeks. Or I could try a helmet light and keep it inside where it's warm.
I kind of wish I had something with wider tires for the snow. Those fat tire bikes seem kind of expensive. I don't think I can convert my bike with it's skinny tires to fat tires without major welding. At least I can use it when there isn't a lot of snow. But regardless, I also need to get ahold of some fenders. Melting snow spray is one reason I don't drive it much.
