Old 11-23-2018, 02:17 PM   #253 (permalink)
ocnorb
R2 - '13 Chevy Volt
Team Volt
90 day: 20764 mpg (US)
Originally Posted by cowmeat View Post
I found out that preconditioning only works if you're charging at 220 volts. Preconditioning at 110 volts will draw some battery power and affect the EV range, so I won't be doing that!
Every day so far I have ended up with between 72-73 miles of EV range
Technically the 220v preconditioning can do the same; when it’s subzero my car pulls 5-6k Watts, while the charger can only put 3300 watts in.
Not often a problem in Florida.
2̶0̶1̶3̶ ̶V̶o̶l̶t̶ ̶-̶s̶p̶o̶r̶t̶i̶n̶g̶ ̶s̶e̶a̶s̶o̶n̶a̶l̶ ̶g̶r̶i̶l̶l̶ ̶b̶l̶o̶c̶k̶
2013 Volt- wife wanted one too. Bye Leaf
2017 Volt Gen2 Red like all cars should be.
1997 Landcruiser (Bruiser) -sadly gets about 11.5 MPG...
