Old 11-24-2018, 05:06 PM   #3881 (permalink)
aerohead
smelting
It's not the melting it. It's smelting it.
Where you dig what amounts to rust out of the ground, turn the rust into iron and add a little bit of carbon that stays with the iron while removing impurities.
Remelting steel and iron to recycle it using an electric arc furnace is common.
I just looked at smelting. It looks like you electrically heat the ore ,while adding a chemical reducing agent.
