Old 09-03-2008, 01:04 PM   #6 (permalink)
eastender43
No Co2 cartridges,please...
They are for emergency race use only,everyone else should use a pump...Why?
I can't tell you how many of these empty CO2 cartridges line the roadways...and they are not cheap!...their only benefit is speed...so they are only needed in a triathlon,or off road race...
I have seen people freeze the skin off their palm with these things...try riding after that!And if there happens to be a problem with your tube,or you didn't find what poked the hole,and it does it AGAIN,immediately,well,....Pumps give you many chances,and work for routine inflation as well....
you just really need a small pump,and a multiple patch kit...You can make small bike size patches from larger automotive ones,and I use a small glass bottle for glue,cuz the tubes of glue evaporate...Likewise the self stick patches deteriorate to uselessness quickly...
Finally,tires with a kevlar belt under the tread(NOT the bead) will let you ride through some stuff that is shockingly sharp...
Get a pump,a mini tool with a chain tool,a patchkit,good belted tires,keep them very HARD,and enjoy the ride,...also watch the road surface and don't ride over sharp stuff!
Flats suck!
