Originally Posted by redpoint5
I personally wouldn't idle to warm up.
I don't, as it doesn't really help when the heating is on as well (for defogging)
Originally Posted by Ecky
My Insight suffers from this as well. The engine even has exhaust heat recovery - there's a water jacket over the exhaust. When it's below freezing and I turn on cabin heat, I start losing coolant temperature
Same here, and it doesn't even need to be that cold.
Idling, the coolant temp drops when you stop & the heater is on.
Driving it, the temperature goes up pretty quickly though.
