Old 11-27-2018, 10:30 PM   #34 (permalink)
cRiPpLe_rOoStEr
Indeed. But anyway, in my homeland I see Ford owners getting rid of the thermostat and running without it even in the winter, claiming the failure rate justifies not replacing it in due time. Well, if I would ever take that risk, I'd try at least an adjustable grille block. BTW I know it's a whole different matter, but Citroën resorted to a removable flap as a way to avoid the bypass valve on the oil cooler of the 2CV.
101Volts (11-28-2018)
