Old 11-28-2018, 02:53 PM   #7 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Anyone remember the Volt used in crash testing that later spontaneously combusted .
Pretty much every Volt that combusted had a physically damaged battery such that electrolyte or coolant escaped. The electrolyte is a very volital material with a low ignition temperature, the coolant tends to rapid discharge the battery.[/QUOTE]
IIRC after an accident, the car is supposed to be drained of coolant to prevent fires. This wasn't done and the fire happened a couple weeks later due to your aforementioned discharge.
https://www.plugincars.com/chevy-vol...re-110154.html
