Old 11-29-2018, 04:43 PM   #6 (permalink)
Piotrsko
I think the starter and header are on different sides. I am proficient in 2.8 or 2.9 colognes.
3.08 diffs are rare as hens teeth unless you want to have them professionally swapped for $2500. I dont know what else in a 8" uses them. I would just use bigger diameter tires, not like space is limited in the wheel well.
Warn makes manual hubs if you have the one piece front end. I forget which year those ended. You can pull the axles if you dont need 4wd.
Autozone has the manual steering box and brake master cylinder, bit of a pita in parking lots.
What could I possibly know about rangers?
