Old 11-30-2018, 05:26 PM   #11 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by 19bonestock88 View Post
Eeeewww, 3.0... lol
Actually the Vulcan V6 is a solid engine, if a bit underpowered... if yours doesn’t have the distributor, you need to watch out for the cam synchronizer, they can fail and the oil pump loses its drive and then you’ve locked an engine...
Same ecomodding ideas apply though... if you can stay off the highway, P&G is your friend... though my Cologne V6/manual truck would get 23-24mpg on longer trips at 60-65mph...
Yup it is distributor.
It's not clearly noted but there is a link in the first post for all the pictures of the vehicle.
Yeah mpg is bad....
It has a code for a recirc valve but thats it.
70mph I saw 21
55 I saw ~26-27
Instrumentation is rough in this car right now lol
And I assume it to have a towing package. Even with 215/70/15 tires 70 mph is 2650 rpms! Not quite in the efficiency range up there. lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
