Bad 3\4 could be bent or misaligned shifter, or the stupid plastic ball in the shifter tunnel is destroyed. Easy peasy fix either way. I used an old 60's VW bug heater knob drilled out to fix mine but some welded a ball bearing on the end. If you aren't in neutral when you install shifter you can't align it.
Towing package will be class 2 2" square mount and wiring stub for trailer.
