Old 12-02-2018, 07:20 PM   #16 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Bad 3\4 could be bent or misaligned shifter, or the stupid plastic ball in the shifter tunnel is destroyed. Easy peasy fix either way. I used an old 60's VW bug heater knob drilled out to fix mine but some welded a ball bearing on the end. If you aren't in neutral when you install shifter you can't align it.
Towing package will be class 2 2" square mount and wiring stub for trailer.
You are the second person to say this. Is this a common fix? I did notice that originally it would kind of grind, but now it wont even engage. You can shift over to third and fourth and it will just sit there in neutral as if the car fell out of gear.
I'm definitely going to look into this.
Edit: Bought 1-2 and 3-4 shift forks. That and some Mercon V and thats an easy 60$ repair! I love having the internet as a resource.
Can you pull the top loader on the trans with the transmission still in the car?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
