Old 12-05-2018, 10:10 AM   #23 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Your charging system is designed for people that never kill the engine to coast. When I was commuting 3 miles each way to work, a good part of each trip was engine off coasting. I found that I needed to put it on a charger once a week to top up the battery. I learned this after a dead battery episode. A 2 amp charger is large enough if you use it often enough.
If the voltage is holding over 14 volts, the alternator is working correctly. If you monitor the voltage when on a charger, the charging voltage will gradually increase to 14.8 volts, hold there for a while, then drop to 13.3 volts and maintain at the level. That's what is needed to fully charge your battery.
The Following User Says Thank You to JRMichler For This Useful Post:
hayden55 (12-05-2018)
