Old 12-08-2018, 08:58 PM   #113 (permalink)
logix
Originally Posted by California98Civic View Post
Bense will give you his own reply I'm sure. But I will say that supposedly this can be done (I have not, nor have I personally met anyone who claims to have done it). But the swap of the 5th gen trans to a 7th gen car will be complicated by the differences in shifter linkages and the seventh gen Civic's immobilizer, if I understand correctly. Wiring and shifter adaptation will be required, but they bolt up.
This is a better question what can be done trans side for more mpg in my 7th gen?. is there better swaps with a taller last gear with more compatibility? Have people been able to retro fit with a taller final gearing? Sorry to ask you two seem to be the most knoweldgeable on the net.
Thank you kindly,
Max
