Originally Posted by OfficeLinebacker
Use the PCV intake hose or just crack the joint between the intake hose and the TB. Failing that, try one of the smaller vacuum lines, and continue to just spray copious amounts of stuff down it's throat with the engine off (use a rag to catch the overflow). You'll see the brown gook it's washing out of the intake.
The above methods don't clean the injectors; similarly, fuel additives don't get the TB, EGR, or, most importantly, the IAC.
Thanks for the suggestions.
I usually just remove the entire intake (sensor and all) and spray down the actual throat of the TB while opening and closing the valve using the throttle control (under the hood). When I clean the TB, I usually add FI cleaner at the same time. I hope to surpass the 200k mile point before the end of this year. I am just under 196k right now.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
